- Location
- United States
NIB Land Cruiser 9.5" ARB Air Locker differential RD142 fj80, fzj80 and many other Cruisers with floating axles. $885 shipped.
I also have NIB ARB CKSA-12 compressor for sale for $125 extra shipped.
Comes with original purchase receipt for the warranty.
Please Note: The RD142 is made for all 50mm carrier bearings. If you are installing an Air Locker into an earlier model Toyota with a 45mm differential carrier bearing inside diameter then you will need to use the higher rated later model 50mm bearings: Timken # 32010X-32010X or ARB # 160116. If your OE carrier bearings have an ID of 50mm, replace them with new bearings of the same type.
Fits the Following:
Toyota Land Cruiser 9.5" Differentials (12 Bolt Full Floating. What does this mean "Full Float"? The axle shaft is splined on both ends, the axle shaft does not support the weight of the vehicle, the bearings do- therefore, the axle "Floats" inside the axle housing.)
Please Note, this will not fit FJ80 / LX450 Front as these are 8" high pinion reverse rotation differentials.
This locker will not work with any of the semi float c-clip rear axles!
How do I tell if I have a full floating or semi floating rear axle? If the wheel hub is flush with the wheel it is a semi floating rear axle. If it has a hub that sticks out past the wheel then it is a full floating rear axle.
Fits all Full Floating Differentials ONLY in the following models:
9.5" Ring gear Full Floating Axles may have been available in the following Land Cruisers:
BJ40
FJ40
HJ45
FJ55
FJ60
HJ60
BJ60
HJ61
FJ62
BJ70
HJ70
BJ75
HJ75
Rear only in Landcruiser FJ80, FZJ80, HZJ80, HDJ80.
Fits the Following:
BJ40
FJ40
HJ45
FJ55
FJ60
HJ60
BJ60
HJ61
FJ62
BJ70
HJ70
BJ75
HJ75
