My alternator on a '89 22RE is giving me grief. It took it out and it came out hard. After removing the bolt from the bottom pivot bracket it to lots of wiggling to get the alternator to slide out. I rebuilt it. Now I can't get it to go back in. It is refusing to go back into the the bottom pivot bracket. Looks like I'm going to have to grind a small ramp into one of the faces to get it to hopefully slide into place. If that doesn't work, I'll have to grind a bit off one of the faces. Hopefully that doesn't misalign the belt to much.
Oh yeah, looks like the joker who put on the bypass hose did it when the power steering pump wasn't mounted. The ears on the spring band camp bracketed part of the power steering pump mount structure.
