SOLD New Orleans,LA/ 1989 Toyota FJ62- 115K original miles
Year
1989
  1. 60 Series
Mileage
115146
Color
white
Time to sell one bad ass 1989 FJ62, w/ only 115,146 original miles. Ella is a head turner. She was my DD from Day 1. First turn of the crank every time, trusted and dependable. 3 owners her entire life and you will see the breakdown below on yrs of ownership and mileage each put on. Clean Carfax-no accidents. Top score of 89 points on Auto-check Records dating back to original purchase. Pampered and well maintain FJ62! Title in hand. Selling b/c I changed jobs, new car and have to be on the road more. Cannot enjoy her and just sitting- driven only 1 or 2 every 2 weeks the last 90 days.
ASKING $40K. Certified Cashier's check only accepted payment. Shipping responsibility of purchaser.
First off everything is in working mechanical order- locks, windows, antenna, 4x4 (which i never have used except the day i bought her to confirm). Only items- windshield spray unit is not working.FJ62 original. Original windshield has a small nick- but do not want to change, to keep it original. Very light and treat surface rust in common areas- lower door panels and very small spic (1/4 dime) on rear roof/top tailgate area. Will post specific pics. Undercarriage- the unit was treated (2) times with a rust protective coating. Original owner did this per the 2nd owner. 2nd owner had it all redone at time of restoration. Oil seep- all seals have been replaced at 112K miles, however there is a very small "seep" that is coming from the Front Seals and Rear Oil pan seal- confirmed by Toyota certified mechanic and my personal mechanic, however the seep is so minimal- not a drip on the gorund, but a wipe every 2-3 days after driving, that we agreed to address when we needed to do any other future mechanical work.
As I was told, the original owner was a college professor- 2 homes in VA and AZ. Drove on average less than 5K miles per year. FJ62 was trailered to and from VA/AZ almost every year b/w 2001- and upon retirement in 2015, was located permanently in PHX,AZ- where the 2nd owner acquired her and relocated her outside of Austin,TX. Majority of restoration work completed by a very high end shop- Eagle Automotive, McAllen,TX. (look em up- talked to owner, he remembered everything about her after 4 yrrs of the work his team did).
I have had a few individuals with extensive mechanical knowledge of FJ60's- tell me this is one of the cleanest and mechanically sound units they have ever seen.
I will cut and paste my inventory of all records:
Auto/LocationDateMileageWork Performed
Vehicle acquired- Annadale,VA
11/25/1989​
73 miles1st owner acquired
Springfield,VA
11/24/1992​
Fuel Tank replacement- recall
Oil changes- 3K miles1992-2003Toyota and various oil change shops
Koons Toyota-VA
9/18/2003​
80,112​
Tune up
Koons Toyota-VA
3/17/2005​
87,572​
Tune up, transmission flush , replaced radiator assembly, replaced rear tail light bulb
Koons Toyota-VA
8/24/2005​
89,880​
Replaced Thermostat
Koons Toyota-VA
4/8/2006​
92,791​
Oil change, check up- drive belts
Koons Toyota-VA
12/16/2006​
95,938​
Koons Toyota-VA
12/22/2006​
96,101​
Replaced Battery
Koons Toyota-VA
4/16/2008​
102,184​
Oil change, check up- drive belts: Replaced Both rear shocks, left outer mirror
Koons Toyota-VA
4/30/2008​
102,361​
Replaced Drivers side mirror assembly, right side marker light buld and Rear parking brake mechanism
Koons Toyota-VA
12/13/2008​
104,534​
Replaced Muffler assembly- inspection
Koons Toyota-VA
10/8/2010​
105,042​
Replaced fuel pump, fuel lines, gear shifting bushings, replaced drive belts, replaced wipers, replaced battery and both tail light bulbs
Koons Toyota-VA
10/14/2010​
105,156​
Checked over all fuel system and lines..fitings..etc checked over
Koons Toyota-VA
3/7/2011​
105,638​
Tighten all drive belts,
Koons Toyota-VA
7/28/2011​
106,076​
Tune up, check up, Replaced AC dryer and converted AC to R-134 system. Recharged and did leak test.Replaced door relay switches
Koons Toyota-VA
8/6/2011​
106,146​
Replaced master door power window switch
Koons Toyota-VA
10/22/2011​
106,636​
Koons Toyota-VA
11/1/2012​
109,251​
Oil change, wheel alignment, Rt headlight replaced, replaced all head light bulbs. Replaced radiator assembly, wiper blades
Koons Toyota-VA
2/11/2014​
110,778​
Inspection- determine valve gasket leaking, oil pan gasket leaking- customer declined. Replaced battery
Koons Toyota-VA
3/11/2014​
111,230​
Replaced Front brake rotors, brake pads, wheel bearings overhaul, replaced seals
Koons Toyota-VA
12/8/2014​
missedReplaced leaking trans lines, flush,
Koons Toyota-VA
8/17/2015​
108,998​
Tune up, check up, replaced battery- TrueStart,
Camelback Toyota- PHX
4/1/2016​
109,166​
Replaced drive belts, Brake flush, oil change and inspection, replaced tachometer, replaced headlight bulbs
4/6/2016​
109,176​
Oil changem tire rotation, replaced brakes master cyclinder, booster, rear window switches
27 yrs of ownership- roughly 4K miles driven per year. Well maintain at Toyota dealership- garage kept- pampered
Sold to 2nd Owner
Apr-16​
109,252​
Driven from PHX to Austin, TX
Eagle Automotive
Mar-17​
110,874​
New brake system- front and rear, Extensive Engine overhaul- thermostat, new water pump, Fan Clutch, Spark plug
PCV Valve, Distributor Rotor, Oil pan set, Timing cover gasket, valve cover gasket, push rod gasket, AC belt pulley, Drive Belts
V-belt, fuel filter install, new exhaust system- y pipe, exhuast gasket, universal converter, Oxygen sensor
Steering kunckle seal/bushing, knuckle seal kit, Drive shaft replacement, Transmission service- flush and filter, fuse overhaul, AC charge
installed new EMU Lift kit, new BF KO2 31' tires and rim
Eagle
Mar-17​
Front and rear 4plus bumpers purchased and installed
Eagle Automotive
17-Mar​
New tires and rims
Eagle Automotive
17-Mar​
Roof rack and rock sliders
Eagle Automotive
Mar-17​
winch
Eagle Automotive
Mar-17​
New Leaf springs, faulty rear right brake line, upper radiator hose, and radiator cap, tint
Eagle Automotive
Mar-17​
EMU Lift kit
4 yrs of ownership- <4K miles driven including driving it from PHX at time of purchase
Sold to me- 3rd ownerMarch 1 2020
113,575​
Steve's 4x4- NOLA
16-Apr-20​
113,630​
Purchased new fuel evap. connection- $350 Spector Offroad, installed and elimanted 10+ yr fuel smell! Also rebuilt knuckles again to Steve's level
oil change and inspection- determine front valve gasket and oil pan gasket lseep- not a leak. Replaced front pinion seal
Oil change
7-Oct-20​
114,450​
Oil ChangeApril 10 2021
115,075​
The current bids have to come a ways up to get this baby! Less than 2 days away from the auction ending. Is it going to sell round 1? It better b/c I made a mistake on the reserve price and cannot raise it! It is priced to move....
New price $34,900.00
Relisted as an Auction on EBay.
Going to BaT next in the event it does not go this week.
Update- 3 offers made. Reserve has been met. This has a good chance of selling by next Sunday. Someone hit that buy it now button! Great truck <$35K!
LCVA- videos have been sent- thank you for your interest
Very interested! The truck will sell this week on eBay.. Reserve has been met
SOLD! I enjoyed my ownership and the fellowship and support of the MUD community! Thank you for all those that directly helped and to the many who shared valuable insights that i leveraged many times. Take care and wishing all the best.
