- Joined
- Apr 21, 2005
- Threads
- 115
- Messages
- 26,101
I would be in for one once they're confirmed to be functional and of good quality.
LITP, I had no problem installing a 5 speed with 40 series cover in my 1981 FJ40 with no modifications other than to the transfer case shifter. A little heat was all it took to bend it to the right place to fit the factory hump cover. It's just a little shorter now. Getting the transmission out someday may pose a bit of difficulty as there's not much room in front of the crossmember tube. I installed the engine and trans as one piece.
I assume you used the same transmission crossmember you were using for the four speed? Mine is a 79 and wondering if I installed the L brackets a little lower if I could get around modifying tunnel. I have the later raised inspection cover that would help right around the shifter. On my 68 I used some fender washers on the front motor mounts to pivot the back to clear the floor when I installed a four speed. It too has very little clearance from the round torque tube. In the past I've removed the rear motor mounts and lower the back of the to pull the transmission but pulling the whole is probably easier.
