Bump to top...
Anyone make a kit to mount a Stock EBrake to the back of the connected Split case?
Bump to top...
dopypuppy, any update? Thanks!
That's awesome news!! Now I don't use Facebook... Could provide some updates here? Thanks!Project has been reborn follow it on facbook. Search for "5 speed 40 series land cruiser" in groups
I've looked at the difference between the pieces of the two and decided just the housing would leave missing many parts that may or may not be available. It also seems that the 60 top cover made some changes at one point. It just looked to confusing would might work and what wouldn't. For me a used 40 series top cover is the only way I would invest in a H55F. The inspection plate on the hub changed the same time the a five speed became a option (10/82=83 model) and is a little taller. The size also changed a little too. Changed just replace it with a later one. I plan on modifying the late cover just incase I ever find the top cover so only driveline mods are needed.
I'd be very interested... $$ ?Just FYI. If you wait a month or so, I'll be offering a reproduction inspection plate for 5 speed conversions. It'll be a replica of OEM with the raised section to provide additional clearance. It will not come with pre-cut holes so you can cut holes based on where you need it. Better yet: it'll be made in Japan.
It's a bit early for a precise number, but I expect it to be $130-ish.I'd be very interested... $$ ?
My 84 is also raised from the factory.
Pete
Both types will be available. Compare the 2 photos in the Unobtainium thread, and you'll find that shape of the covers in the first photo is different from that in the second.Is it going to fit the 79-82 opening or the 83+? I didn't realize the shape of the opening changed until I picked parts off a 84 HJ47RV last year. While is had a H41 the opening was raised for the five speed which makes me thing Toyota standardized the opening when it was modified for five speed.
I took a look at the other thread and could see the difference in the mounting holes. This looks like a easy way to go rather modify the opening. Still haven't located a cover that hasn't required taking out a mortgage.
Also like no holes option which allows using late 40 series boots or one from a 60 series. Have both so which cane I would end up with would determine which boots. Price point also looks good. Are these metal or fiberglass?
Looks good. You have plenty of time as the top plates will not be manufactured and posted until July. Sent PmI don't want to hijack this thread, so for those interested in the inspection cover, please follow the Unobtainium thread (scroll down to post 839).
