New idle
crholliday
Frisbeetarianist
OKC, OK
New EFI Main Relay - $16.47
2 New O-Rings for the ISC Valve $0.40
1100 RPMs at cold startup - Pricele$$ :D
FWIW, the EFI Main relay did nothing for the cold start idle (or anything else I can detect).
Previous to the O-Ring mod, my cold startup idle was 1800 with no A/C, 2100 with A/C. Then it would slowly drop to 800 in Park or Neutral w/o A/C or 1300 w/ A/C. With the mod, cold startup idle is 950 w/o A/C, 1100 w/ A/C and after warmup in P or N the idle is 625 w/o A/C and 800 w/ A/C.
Thanks to Safari4x4.com for the mod specs.
Chris (w/ new sig )
Wow that sure was pretty high for cold starts prior !!! mine goes to about 1100 rpm on cold start and slowly within a 3-4 minutes to 600 rpm..then i'll pull out of the driveway and be on my way
