I am putting my new ICON Six Speed wheels on today and was wondering what they should be torqued to. Should they be torqued per the factory specs? Or is there a new value? Checked ICON's website and didnt't find anything.
BFG TA/KO2 285/70R17 should fit fine without a lift, as that's the standard tire Toyota recommends with the Rock Warrior wheel. You can add an OME lift or just strut spacers, but neither should be needed for clearance if you use a +50 offset wheel. Keep in mind that a lift doesn't really buy you clearance on the front IFS, it just changes the starting point (i.e. a 2" lift gives you +2" of up-travel but -2" of down-travel). The rear solid axle is a different story.
With the +25 offset Icon wheels you might still need to remove mudflaps and/or the forward "mud" flap (air dam?) because the lower offset increases the arc of the outer edge of the wheel, which can cause some rubbing in places that the +50 RW wheels would clear.
That is stock suspension?Here is a picture with the Icon Six Speeds and 285 70 17 Goodyear Duratracs on stock suspension. I had to remove the front mud flaps, pull the front of the fender liners forward and occasionally I will get some minor rubbing I believe on the body mount behind the removed mud flap. Will need to hammer on it a bit. Hope this helps.
It looks level...
I searched for ICON Six Speed hoping someone had posted pics of these with 285/70 R17 tires and voilà here it is. Its even on a black 200 like mine. I am considering Duratracs too. Are you still happy with the wheels and tires?Here is a picture with the Icon Six Speeds and 285 70 17 Goodyear Duratracs on stock suspension. I had to remove the front mud flaps, pull the front of the fender liners forward and occasionally I will get some minor rubbing I believe on the body mount behind the removed mud flap. Will need to hammer on it a bit. Hope this helps.
