Larson Electronics has announced the release of a high intensity LED light configured to allow operators to produce red or blue light output from the same fixture. The LEDLB-24-VISRED LED Light Bar features rugged waterproof construction designed for extreme conditions and a dual color LED design that allows this unit to serve in multiple applications. [...]
The LEDLB-24-VISRED LED light bar is a high output, dual color LED fixture from Larson Electronics that gives operators the power and functionality of two lights in one compact fixture. Featuring four rows of LED emitters, two rows producing white light and two rows producing red, these light bars are ideal for law enforcement, security, and hunting applications where colored light is often desired. These high output LED lights are fitted with dual pigtails with Deutsch connectors to provide secure wiring connections and have an IP68 rated waterproof housing and unbreakable polycarbonate lens to withstand abusive weather conditions and handling. These dual color LED lights can be wired through a multi-position switch which will allow operators to toggle between red or white output, or run a combination of both colors if desired. The Cree LEDs used in these units provide over 50,000 hours of operational life and high power output that surpasses that of comparable halogen lights while using less power. Since these lights are LED, they draw far less current than incandescent lamps and produce over 4,000 lumens while drawing only 72 watts at 6 amps from a 12 volt electrical system. The LEDLB-24-VISRED can withstand rapid temperature changes of -40 degrees Celsius to 85 degrees Celsius and submersion up to 3 meters, making it fully waterproof and protected against the damaging effects of driving rain and extreme environments. The internal LED drivers automatically sense and adjust the incoming electrical current, allowing operators to connect these powerful lights to any source of 9 to 32 volt dc current without the need for an external transformer. These units also actively monitor heat and adjust the duty cycle of the current fed to the LEDs, resulting in maximum output while reducing heat buildup, thus improving overall performance and the longevity of the Cree LEDs. Mounting for these LED light bars is through included U-brackets with stainless steel hardware and a single mounting stud. This mounting system provides secure placement and allows operators to adjust vertical angle once the unit is positioned. These dual color LED lights provide the functionality of two lights in one package and are ideal for applications where operators often need to provide red illumination as well as general purpose white illumination.
“The LEDLB-24-VISRED LED light offers both white and red output for operators who need a low light option for more covert operations and bright, white light for area lighting when safe to do so,” said Rob Bresnahan with LarsonElectronics.com. “By combining them into a single fixture with dual power inputs, we give operators the freedom to activate either or both LED arrays depending on the conditions. For original equipment manufacturers, the dual array reduces both the installation time and space needed for this type of lighting.”
Larson Electronics produces a full range of industrial and commercial lighting equipment, LED work lights, portable LED lights, LED light towers, and LED boat lights. To view the entire Larson Electronics line of industrial grade lighting solutions, visit them on the web at Larsonelectronics.com. You can also call 1-800-369-6671 to learn more about all of Larson Electronics’ lighting products or call 1-214-616- 6180 for international inquires.
Link
Link
