My 88 fj62, 3fe, fuel injected is idling a little high @1150 rpms. Might not bother me too much, but with the price of gas....well you all know. Any fixes?? For the idle problem that is.
cabron said:Checked for large vacuum leaks? Take carb cleaner to entire motor area carefully listening for changes
tracksuit hobo said:you could also use a propane torch to look for leaks. it's easier to point the nozzle into specific places and will last longer. just don't light it! good luck - TSH
bigbertha said:Hi-
If the TPS does not budge with a little hand pressure with the top screw loosened then you will have to take off your TB. The TPS is plastic so do this with care.
schaats said:Could you please explain more detail about using way of propane torch when I want to find leak point ?
I'm very interested in your post but I can't understand![]()
Thank you,
Oh, Min Seok
tracksuit hobo said:what you do is turn the valve (on the propane bottle attachement) to let the gas out, then point the nozzle at specific lines or valves (or even intake manifold), - if there is a leak, the uningnited propane will be sucked into the motor via the leak, and you will notice a change in the idle RPM.
By holding the body of the propane bottle, the nozzle can be pointed into tight spots easier and the flow of gas will be constant.....rather than having to hold your finger on the spraycan to keep the carb cleaner spraying.
it works well, without spraying carb cleaner everywhere. The fumes from carb cleaner can get nasty if sprayed on hot surfaces. and since we're using flammable materials, if a fire occurs, the propane fire will be shorter lived.....
i found 2 leaks this way, through cracked lines.
