CruisinGA said:No, it is a clamshell type assembly. Look underneath for screws that hold the two pieces together.
CruisinGA said:try tilting the wheel?
I know I've had mine apart, pretty sure I took all of it off and put it back on without any drama.
tech_dog said:I just did this. Here's the trick:
1) Remove all the screws. Make sure you note where the long ones go and where the short ones go.
2) Tilt the steering wheel all the way up.
3) Pull the bottom cover off BOTTOM end first. You have to flex it a bit, but you can get the bottom back part out from between the dash and the stearing wheel.
4) Once the bottom is off, you can twist it a bit and slide over the indicator lever.
5) After you get the bottom off, tilt the stearing wheel back down and take off the top cover.
To reinstal, just do this in reverse.
KC Cruiser said:I just loosened the bottom part of the dash under the column and the bottom portion of the cover came off like buttah. Its only like four screws or something to loosen the lower dash, very easy to do.
-Andrew
Hayes said:Mine only has the bottom half...
Anyone know a source for cheap steering column cowls?
Hayes
