- Thread starter
- #21
So I had some issues with oil blowing by the seals in the turbo and getting into the intake and the exhaust. I had taken the banjo bolt and made it a little bigger before my trip and this had reduced the amount of oil I was seeing in the intake but during my road trip across canada I continued to see both oil in the intake and oil in the exhaust when the engine was cold (I assume probably because the oil was thicker and as such higher pressure in the turbo)
I've been doing some reading online and it sounds like an oil restrictor might be a good idea (as I have an unknown amount of oil trying to make its way into the turbo at an unknown pressure) reading around online it sounds like for a T3 turbo I should put in something like this:
Oil Inlet Restrictor - .065" hole size 1/8" NPT (for Journal bearing and larger GT BB) : atpturbo.com
Sounds like it can help with the problem I have... and also increase the life of my seals (assuming my current oil pressure is higher then it should be)
I figure I can make the same thing by brazing my current fitting shut and then drilling it out the same size. (Hence free fix!)
The other thing I'm thinking of doing is drilling out the banjo fitting a bit bigger (in the part that connects to the hose) as I think that's my current restriction.
Failing this I'll be back to square one and actually welding a bung into the oil pan.... Just trying to avoid the nasty mess that'll be...
Does anyone have any opinions on this? Especially guys who have done turbo's before?
