Need mechanic in Boulder/Denver!
Bellingham>Boulder
I have been looking to install air conditioning into my 80 and can't find a competent mechanic. I swapped the 1hd-ft into my 80 last fall and the engine I put in never had a/c on it. I will need a mechanic that has a little skill with machining since it's not an r/r job. All the shops that I've talked to won't go near it!
I need to fit a pulley, an idler/ tensioner, and belt. Then it will need some a/c piping. I allready have the pump fitted.
Thanks for any advice. -Ryan.
Call Slee offroad, if they can't do it I'm sure the could tell you a good place to go.
Jon Davis Fabrication . Home #303-470-7031
