Need help with some part no.'s
Kauai, Hawaii
Like the title says I need help. now before the flaming begins, I have used the search disfunction and found nothing that help. so with that said I choose to pick the minds of those inthe know...
I ordered wheel bearing kits from Downy and some of the no.s match some don't so here goes.
They are Koyo bearings;
first set-X2- the box has these #'s (as it appears on the sticker)
140015-1
JR 0423H
On the bearing it has
6308RSC3
It also has 022 on one side and 037 on the other
2nd set-X2 the box has these #'s (as it appears on the sticker)
140014-1
404 0728H
On the bearing:
JLM104948
3rd set x2 has these #'s
140013-1
RLH 0728H
On the bearing;
LM102949
the last 2 sets I don't think are Koyo's
if you have any insight drop a line.
thanks:beer:
What is your question?
oops sorry:grinpimp: should've been more clear. what bearings do I have? when i got the parts from Downey the #'s didn't match the #'s on the original bearings:bang:. so i don't know which ones are which.
thanks:beer:
If you remove a bearing from manufacturer A and replace it with a bearing from manufacturer B, I would not expect the numbers to match. Each manufacturer has their own numbers, don't they?
Do the new bearings fit?
I understand that A and B won't match. my ? is which part #'s correspond to what?:confused:
The bearings only fit where they fit. The outer bearing will not fit in the inner location.
Just install them.
Or send them back and get a full set of matched made in Japan Koyos from Cruiseroutfitters.
Or a full set of matched made in Ohio Timkens from Autozone.
No. Name Toyota P/N OE Manufacturer OE P/N
1. Bearing (For Steering Knuckle Arm) 90366-17001 KOYO TR0305AF4(On Box), TR0305A(Inner, Outer lace)
2. Bearing, Tapered Roller (For Front Axle Outer Bearing) 90368-45087 KOYO LM102949(Inner), LM102910(Outer lace)
3. Bearing, Tapered Roller (For Front Axle Inner Bearing) 90368-49084 KOYO JLM104948-N(Inner), JLM104910-N(Outer lace)
