Need help with Identification of axel
I received a fj40 axel with either 4.11 or 4.10 gears, fine spline with passenger side drop...
Can some one tell me what year this is from???
I need a replacemnt 3rd member ,want to ge the correct year
Thanks for the help Brad
rear axle???? or front... if you pull the third ... they are stamped on the ring gear... most of them... if it is not.. count the teeth and pinion..... 9 on the pinion and 37 on the ring gear gives you 4.11 so 37 divided by 9...
40 and 60 thirds will fit..
So 40's and 60's all year's will fit???
It is for a rear
Thanks for the help
