Need help locating part number for body ecu
SF Bay Area
Looking for the part number for body ecu for my Puerto Rico spec 06 Land Cruiser. Local Toyota dealership wasn’t able to find it (or didn’t try very hard)
Hoping someone on mud has better skills
Vin is jteht05j962085831
Much appreciated!
Sorry, that is not it. That's just a junction block and sits on the lower wall next to passenger right foot.
The one you're referring to is right behind the radio head unit. Need to pull off the bezel, the head unit and you'll see it tucked up to the bottom side of the dash framing. It's a bit of a pain as they have it crammed in there well. ALL the wires into the connectors feeding into the module will be a light blue.
I looked through all the diagrams on Partouq and couldn't locate it. Best bet is to access it you and then you might be able to obtain a part number off of it without having to remove it. I'll browse though it again and post up if I come across it.
Thanks Andrew - i still don't know where it is in the diagram though.... clearly it's relocated in my car and not behind the nav unit
Much appreciated!
89111-60040
Unfortunately, it's discontinued from Toyota. Used only.
Thanks everyone - are you certain that part 89111-60040 network gateway = body ecu? in older models this part is called body control module..
Can't confirm yet. I located a unit from a part out with that part number (60040) and it's a single connector module with only 8-10 wires. Most body modules will have a lot more going in and out of them.
It's possible that the orig part number you came up with for the junction box does in fact contain the body module with in it. Or it is contained in the nav unit since the hvac/nav hardware are integrated.
Time to break out the wiring diagrams. Is there anything that you can spot that's specifically different on the PR100 from a NA100?
The following are listed as "computers":
Diagram 84-01: SWITCH & RELAY & COMPUTER
part 89227 : COMPUTER, MULTIPLEX TILT & TELESCOPIC
part 89730 : COMPUTER ASSY, SECURITY WARNING
part 89111 : COMPUTER, NETWORK GATEWAY
part 85933 : COMPUTER, SHIFT LOCK CONTROL
Diagram 84-04: ELECTRONIC FUEL INJECTION SYSTEM
part 89661 : COMPUTER, ENGINE CONTROL
Diagram 84-14: ABS & VSC
part 89540 : COMPUTER ASSY, SKID CONTROL
part 89630 : COMPUTER ASSY, TRANSLATE
Diagram 86-03: NAVIGATION & FRONT MONITOR DISPLAY
part 83244A : COMPUTER, MULTI INFORMATION DISPLAY
part 86841 : COMPUTER, NAVIGATION
Diagram 84-19: ELECTRONIC MODULATED SUSPENSION
part 89293 : COMPUTER, SUSPENSION CONTROL
Diagram 84-21: AIR BAG
part 89952 : COMPUTER, OCCUPANT DETECTION
Diagram 84-24: ANTI-THEFT DEVICE
part 89780 : COMPUTER ASSY, TRANSPONDER KEY
Diagram 86-06: CAMERA & REAR MONITOR DISPLAY
part 86792C : COMPUTER, PARKING ASSIST
Maybe the nomenclature you are using is incorrect?
The only computer behind the center console of the dash is the Network Gateway Computer.
