Hello Mud,
I am new to the 70 section and this series of Land Cruiser. Recently acquired a 77. One of the rear tail light lenses were cracked/broken so in looking to replace them I sourced some DEPO LED lights. Now I am running into a issue with them and I am stumped. I am not super comfortable with electrical issues, but this looked like a plug and play solution. Here is the issue:
When I use either indicator (L/R) both tail/break lights (LED portion) flashes, like an indicator.
- I didn't have this issue prior with the incandescent lights
- It doesn't happen when I turn the parking/headlights on
- If I leave one side incandescent and the other LED, it doesn't happen either
Here is what I have checked
-All socket seems fine
-Harness seems fine (no damaged or lose wires)
-Bulbs seem fine
I haven't been able to locate the ground, which I have researched could be the issue, but it isn't a issue with the old lights. I don't have access to a wiring diagram. Any help or suggestions are appreciated.
Thank you
-Bulbs seem fine
Thank you
