SOLD NC: 1998 Toyota 4runner
Year
1998
  1. 4Runner
Mileage
271000
Color
rgba(143, 141, 26, 0.21)
I’ve owned this 4runner since 10/2015 and has served as my daily driver. Recently picked up a Tundra and as much as I'd like to keep them both, there's just no room in the driveway for everything. Well maintained and cared for, never let me down. Most if not all of the typical 3rd gen issues/mods have been addressed and it's ready to go wherever. Southeast vehicle it's entire life. According to CarFax (received at my time of purchase and zero incidents since) the only incident was a minor collision at left front on 12/19/2008.
Located in Cary, North Carolina.
$9600
***If link to image gallery doesn't work, message me and I'll send it directly***
1998 Toyota 4Runner
SR5
3.4 V6
Automatic Transmission
4x4
271k miles
Trailer Hitch with 4 Pin Harness
Full Size Spare
Pioneer Bluetooth Head Unit
Weathertech Floor Mats
All original factory glass
Engine Oil changed every 5k miles or 6 months, whichever sooner. Always Mobil1 Synthetic 5W-30 with Toyota Oil Filters and drain plug gaskets.
6/2022 Alternator (Toyota 270606219084)
6/2022 Transmission, Transfer Case, Front and Rear Differential Fluid Change (Valvoline MaxLife ATF, Amsoil Diff Fluid. Toyota Gaskets and Crush Rings 90430A0003, 9043024017, 1215710010, 3517830010).
4/2022 Tires Rotated and Balanced (Discount Tire)
1/2022 Air Filter (Denso 1433040)
1/2022 Power Steering Service and Flush
*1/2022 Power Steering Pump ~ Uninstalled Backup (BBB N9900208)
10/2021 Upper Ball Joints (Toyota 4331039016)
10/2021 CV Axle Driverside (NAPA NCV 944013) * Original Driverside included, damaged boot
7/2021 Tires x 4 (Toyo Tire Open Country A/T III P 265 /70 R16)
5/2021 Wiper Blades (Toyota 85212YZZ03TM)
9/2020 Battery (Toyota 0054424FT2530)
9/2020 Ignition Key Cylinder Rebuilt by Locksmith
7/2020 Timing Belt, Bearings, Tensioner and Water Pump Service (AISIN TKT025)
7/2020 Valve Cover Gaskets and Bolt Grommets (APEX AVC832S)
7/2020 Spark Plugs and Wire Set (NGK)
6/2020 Intake Manifold Gaskets (Toyota 1717662040)
6/2020 Thermostat (Toyota 9091603075)
6/2020 Engine Harmonic Balancer Bolt (Toyota 9011916006)
1/2020 Fuel Filter (Toyota 2330062030)
1/2020 PCV Valve (Toyota 1220462010)
10/2019 Positive Battery Terminal (Toyota 9098205035 90982-05035)
9/2019 Tacoma SR5 Wheels (New Factory Takeoffs)
9/2019 Accessory Belts (Dayco 5060840)
8/2019 CV Boots Inner (Toyota 0443835040)
6/2019 Radiator and cap (Toyota 16410AZ011 and 1640120353)
6/2019 Radiator Hose (Dayco D71929)
4/2019 Engine Cooling Fan Clutch (Aisin FCT-013)
4/2019 Brake Pedal Pad (TOYOTA Genuine (47121-12020)
6/2018 4 Wheel Alignment (Automotive Performance and Chassis)
6/2018 Bilstein and OME Suspension Upgrade
Bilstein 5100 Series Front and Rear Shocks for 1996-2002 Toyota 4-Runner 4wd (Package) 24-248730/24-249966 (Bilstein)
Old Man Emu 906 Rear Springs
6/2018 Tundra Brake Upgrade
2005 TOYOTA TUNDRA 4.7L V8
Wearever Brake Calipers Part No 19-2712N
AKEBONO ACT976 Brake Pad
CENTRIC 12144118 (121.44118) Rotor
CENTRIC 11744075 (117.44075) Disc Brake Hardware Kit
CENTRIC Hydraulic Hoses 15044362
Stabilizer Bar Links MOOG K90681
Date N/A
Transmission Cooler (B&M Super Cooler)
Rack/Pinion, and Swaybar Bushings (Energy Suspension)
Lower Ball Joints (Previous Owner)
Upper Radiator Hose
Starter Motor Contacts Replaced
