Reading turbocruisers HG thread I came accross this post by MoJ...
Is this normal for 80's or is ANY amount of coolant disappearing cause for concern?? Anyone in the HG club recall if your coolant levels were stable leading up to your blown HG.
Other than the HG and PHH... are there any other likely places to look at??
I figured I would throw this into a new thread since I have also been tracking a slowly falling coolant level using the sharpie method. I've lost around an inch over the last year with no apparent weeping at the head/block interface and nothing obviously leaking from the PHH. Never seen a drop on the ground underneath the truck even after sitting for weeks at times.MoJ said:Although I haven't had any other symptoms I did notice I'd lost a little coolant over the last year. I don't check it that often but made a mark on the overflow tank with a Sharpie about a year ago. It's down a little when comparing cold to cold. I couldn't find any good reason it should have done that if everything was operating properly --- anyone know?
