First off, I have to say that Lee at raceshock.com was great about getting me all the parts I needed and VERY helpful with my questions!
I bought used Sway A Way coil overs off e-bay.
This is the only way I could justify C/O on my Tacoma.
Even with the cost of the C/O and a rebuild kit from lee@raceshock.com I was still going to save myself about $500-600! Plus I would know the shocks intimately since I would be totally rebuilding them.
I used the link from bajataco for initial instruction and to see how complicated this project may be. The very good write up and photos are here Tacoma - Sway-A-Way RaceRunner Rebuild .
However, my used C/O shocks were corroded, heim joints ruined, dirty and needed a lot of TLC!
I will try not to repeat the bajataco instructions but rather add to them with what problems I ran into and how I solved them.
I had problems getting the 'cap' off the shock body - it was corroded to the shock body. I had to get a hammer and chisel to persuade it loose and slide it up the shock shaft.
I had the luxury of clamping the aluminum top into the vice since I was replacing it with a new one, same with the adjusting collars - so I hammered on them to remove the valve body.
