Well I finally met my first Cruiser Head in NY. GLTHFJ60 aka John and I met up at a local stip mall in Albany to kick some tires and drive around the block a time or two.
First things things first...John knows his stuff. I was amazed by how much this guy knew off the top of his head about 60's. Thanks John.
Two questions came out of this meeting from some things John noticed.
1) He spotted right away that the shackles on my 2.5" OME lift were on upside down. (PO did it) Since this is my DD and I won't be doing any serious wheeling any time soon, should I worry about flipping them. His recommendation was not to worry about it. The truck rides fine so I'm inclinded to leave well enough alone for now. This summer when I get to Salt Lake and have an extra car again, I can tackle the project.
2) I noticed that my front right tire tips out (camber? or which ever one can't be adjusted on a 62) much more than the left. The tire has a very slight bit of play in it but nothing crazy. John mentioned it might be a bent axle housing. The truck drives straight and tracks very well. The PO mentioned about 6 times that I should take it to an alignment shop. Do you think he knew and wanted me to find out but not before I bought it? What other issues will the bent housing cause besides uneven tire wear? How do I confirm the housing is bent? Is the alignment shop the only way to tell for sure?
Thanks.
Here are a couple of pics from the parking lot. I'm blue and John is white.
Thanks.
