multi use flashlight (1 Viewer)
batteries (12?) life: 5 mins... :)
that was fun .. ! and more coz they said it's for you who love outdoors.. mean to me you love be outside in the night for just 5 mins ..
I will keep my " the pod light " for more hours of light !
nah, you just need it for a minute to check for bears around the tent and then grill it on the hoof, so to speak... mmm.... bear steaks... :D
Lamp Output: 4100 Lumens with an Adjustable High Efficiency Reflector
Dimensions: 57mm x 230mm
Power Supply: 12x2/3A 1500mAh Cells 14.4V
Battery Lifetime: 5 Minutes
Bulb Type: 100W Halogen
Expected Bulb Life: 2000 Hours
Casing: Aerospace Grade Aluminum
Tail switch: On/Off Button
Warranty: One Year
hehehe, I notice their burn paper bit. I have an old WWII night time aerial photography flash bulb with reflector. This is one of those never set off close to you type flashes. When used with the reflector it will easily ignite a sheet of newspaper. Sadly the flash capacitor unit I had for it died. It went boom one day when I was charging it up. I see MIT now has a bit of history on Edgerton's flashes up on the web.
