I'm a little late to the show, and I'm sure you know way more than me, but that is probably the spud shaft adapter you're looking at. My 40 is a 10/74 build and my case has no markings in that location and a way different front output cone.You should probably check what you actually have. 4 J would be October 74. These are the transition four speed tranfer case. The input gear and high speed gear are the same ratio as the three speed cases. The low range gear is same as the later four speed. The three speed case input gear will be 10 spline. The October 74 case would be a 16 spline input shaft.
