Sorry if this has been covered in another thread, or this is in the wrong spot. I am specifically interested in the 100 series so felt it appropriate. Mods please move if necessary.
I am trying to find places to mount accessories, electronic accessories in particular, in my 2003 LC. It was much easier in the 80. I am hoping to see examples of what others hace done. I understand I will need to get creative, but I am hoping not to reinvent the wheel. Thanks in advance for any ideas.
1. 12V Aux plugs (cigarette lighter type) and the dual USB plugs of the same form factor in the front console area. In my 80 I had them on the side of the console next to the passenger's knee. I haven't pulled the console apart but is there enough clearance behind there for the back side of the plugs? Any other clever locations?
2. Fuse block to handle front cab area devices like radios, aux plugs for GPS/tablets, etc. I have a Blue Sea 6 position block, but can't seem to find a good flat location out of the way to mount it.
3. 12V Aux plugs (1 or 2) in the rear cargo area. I was planning on the PS trim opposite the factory DS plug. Is there enough room with the rear AC unit back there? I have the ARB drawers so I could put it there, but I want to have a always hot plug in the back available when I remove the drawers.
4. Power post and fuse block in the rear cargo area. I currently have a fuse block bolted to the side of the drawer under the wing. This powers the ham radio and fridge. I want to move this so it will be available when I remove the drawers and I want to use this space for other things. Eventually I will be adding an inverter and running 2ga or 4ga wiring under the truck and into the oval plug behind the rear bumper. I want to terminate this to a power post, probably inside the long storage compartment on the PS. I could put the fuse block in there also, but not sure if there's enough height to change fuses. The drawers block access to the lower storage compartment.
5. What is the best way to run a coax antenna cable from the cargo area to the exterior rear roof area? Is it going up in the gutter from the bottom of the tail gate and hatch? Or is there another way?
