Motor Mount ?
Garner, NC
I should post this in tech, but I figured I'd start here. Anyone know what type of bolt connects the driver side rear motor mount to the frame in a 40? I've been doing some work on the fenders and realized that this bolt is extremely loose. Hence, probably why it flexed enough to send the fan into the shroud at the last Uwharrie run. Is it welded to the frame (because it spins when I try to take the cotter pin out), or do I just need to get another wrench inside the frame rail?
I could look but I'm thinking about it now and I'm at work... working...on Mud ... :grinpimp:
I don't think it would be welded to the frame but I don't have a 40
working on mud also :grinpimp:
I should have looked at the SOR catalog. Seems that mine is upside down? Nut is on the top, and bolt head at bottom. But then again, I've got a cotter pin style nut on the top of mine.
Cool, I was hoping it was NOT welded and I didn't pop the weld with my wheelie...
I'll get that tightened up... and fenders on.
