The earlier H and 2H were sleeved, and the later ones were parent bore.
The compression numbers that are in the upper 300 range are on the low side of things.
If the numbers are changing a lot hot and cold - check the valve clearances. There will be changes due to temperature....
Make sure that on VSV shutdown engines that the choke plate is open while testing (it should be by default).
On diaphragm fuel controlled engines, make sure that the throttle plate is wide open.
(note that I didn't read the thread, just the last couple of posts).
~John
Thanks John. If you would, please chime in on the numbers posted up in this thread, starting from the top. And can you verify the accuracy of the FSM (398 psi being factory spec for a 2H, 30-35 PSI being the max healthy differential)?
