I'm at a dead end here with my truck and I'm hoping you guys can help. I've searched this site, my FSM, and almost the entire internet and cannot find any info on this. I have a bad misfire, a flashing cel, and no misfire codes whatsoever. The truck is behaving exactly as if it has a bad coil pack but I have none of the 300 codes. Instead, what I have are a bunch of EGR codes. I've owned this truck for four years and have put 130,000 miles on it, and have replaced probably 6-8 coil packs. Every time the coil pack gives itself up as a p030x code pointing at the bad coil pack, and sometimes I get The P0300 random cylinder misfire code.
Here's some history on what's going on now:
For the past week or so, I've had a recurring catalyst code (p0425 Catalyst temp sensor bank one) which I've cleared a couple of times. It has been taking two or three days for that to come back. My original thought is that I have a bad O2 sensor or something simple, but with what's happening now I'm wondering if all of this is connected. Over the same period of time, the truck has been acting as if a coil pack is going out. The truck will misfire for five or 10 seconds and then it will go back to running like normal. Unlike all previous coil packs, I have no misfire codes. Also unlike all previous coil packs this misfire is intermittent, where in the past they've always just died.
This is where it gets weirder. Yesterday morning I started the truck (cold) and it was misfiring, and the CEL was flashing. I shut the engine off, plugged in my scan tool, and I got a bunch of EGR codes along with the catalyst code that I've been getting lately. I wrote down the codes, cleared them, started the truck and instantly got the same codes again in this order:
P0425 Catalyst Temperature Sensor (Bank1)
P0400 Exhaust Gas Recirculation Flow Malfunction
P0403 Exhaust Gas Recirculation Circuit Malfunction
P0404 Exhaust Gas Recirculation Circuit Range/Performance
P0406 Exhaust Gas Recirculation Sensor A Circuit High
My gut is telling me to start switching out coil packs, as it's running like it has a bad coil pack, but this does not make sense logically. Also, as I understand it, these trucks do not have an EGR system, so the EGR codes are throwing me off completely. So before I start switching out coil packs..has anybody else experienced this or can anyone point me in a different direction?
