I'm trying to locate this strange noise coming from the front of the engine. It almost sounds like a bearing or something behind the timing gear cover. I thought it was the water pump, checks ok; smog pump is ok; not the A/C pump. It only occurs when I first push the accelerator, pings and pops a little more, then stops as the rpm's get higher. It's a high pitched metallic sound, almost a screaching ping, from something that is turning. Sounds like something is clanking against each other. The engine was rebuilt about 2 years ago. I used a stick to determine I really think it is coming from behind the main belt pulley thingy. Is there even a bearing in there somewhere? Any help is appreciated. When I had the water pump belt off to eliminate things, the noise stopped upon giving it throttle, as if tension was off the main pulley, if this helps.
