My FJ 62 was running great except for a high idle at about 1200. So I took off the throttle sensor (the one with two screws) and cleaned it out real good with carb cleaner. It works much smoother now.
I also took off the sensor in front of that one (the one with three screws) and made sure it was working well. Is this the one they call Throttle positioning sensor? Opened up the inside and checked everything but didn't spray any carb cleaner in there. The thing seemed to turn out just fine while apart. Put it all back together and now I have a major problem. It idles fine now but it surges real bad above 1500 and won't go above 2k RPM with a severe loss of power. What did I do to screw this up? I have checked all vacuum leaks and like I said, ran great before I did the above. Your help is mucho appreciated.
