Merging front bj60 harness with rear FJ60 harness
Nanaimo BC
One of the last items oustanding on my 3b swap is hooking up the rear wiring harness. I do not have a good electrical understanding (yet, I am sure when I am done I will be an expert..) and this has stumped me a bit.
I have put the harness and drivetrain out of a 84 bj60 into a us 85 fj60. The 2 plugs at the rear harness connection are different, and the number of of wires do not match (even considering the diesel sedimenter) . I have pdfs of the FSMs for both trucks, but have been unable to decipher the color coding due to a few wires with the same color scheme and low quality pdfs where I cant read the color coding on the wiring diagrams.
I would just swap in the rear harness, but the bj60 one is wrecked due corrosion.
I want to cut the ends off the front fj60 harness (not used) and the rear bj60 harness (not used) to make a short adapter cable. I just need to identify what wire does what...
Does anyone have a readable copy of either wiring diagram for these 2 models and years?
Is there a way to trace what wires do what with a multimeter/testlight/etc?
I know I could figure this out by pulling out both rear harnesses and comparing/merging them, but I would like to avoid this if possible.
Send me a EM or PM with your e-mail address and I'll send you 6 pics with the wiring diagram. Each pic is +/- 700Kb.
It's FJ/BJ mixed diagram. It's up to you to figure out what is relevant for your truck. Sounds difficult but when you see it, it's easy to work with.
Rudi
I ended up cutting the harnesses and directly splicing it near the driver's rocker panel. It took a few evenings for me to figure out as a number of the wire colors didn't match, but ended up working fine.
