drbrady
Hi brady,
I'm in the same boat with a '76.
I have the piece you are talking about, the rear seat support, mostly intact but needing a rebuild.. I think I can re use the floor panel and just make new edges and the back lip, going to blast it and see what is left.
The over all width is 63 3/4 "
It basically a box, made up of 4 pieces by the look of it. If some one has more detailed dimensions that could be taken to the steel shop so they can break the pieces into the appropriate shapes,it would be helpful.
If not, I am going to make dimension drawing when I fabricate mine.
Other than a few special pieces, with curves for the door lip and the tub surround top, most of it is pretty straight forward stuff.
I was thinking of using the frame as the jig for the back part of the tub, cutting it off at the door pillars just like Mr T did where it bolts to the door pillar.
I think it may be possible to do the middle floor section the same?
I was going to turn the front part of the tub over after I cut the back part off and make a jig to hold the door pillars in the correct place.
I need the dimension for the door pillars. The center to center distance of the two 1' diameter holes for the top posts.
Thanks jb
