master cylinder
Newmarket Square :(
Website
mysite.verizon.net
Is anyone running this specific setup?:
later 2F (with original manifold), trollhole carb, power brakes?
If so, what are you using for a master cylinder and booster?
Anyone not running this setup feel free to make suggestions. I'm just getting in to researching this and am seeing options of 80 series, mini-truck, metro, and even GM. I had a stock carb on it and it looked like an 80 series setup would still hit the carb. I've since replaced the stock carb with the trollhole one and it at first glance (from recollection) seems to leave a little more room.
Thanks for any help,
Aaron
I tried a 1990 80,s MC on my truck and it did not work.
It seems the stroke bottomed out before any significant pressure built up.
I ended up buying a rebuild kit for the original so I now have a slightly used 1990 80,s MC for sale.
I did read on here that the 80 MC should have worked.
Interesting, I was under the impression that as long as i could get this to fit [without hitting carb] that it would work. Thanks for the response.
Aaron
