SOLD Maryland: 1987 FJ60 Toyota Land Cruiser
Year
1987
  1. 60 Series
Mileage
228045
I will let go of my beloved Toyota Landcruiser FJ60. I am not in hurry to sell it. I will let go for $10,000.00 (OBO). Everything works except for the horn. AC works, but the clutch makes some sound. During the past summer, I welded and all the rust spots in the frame. Now, it has very solid frame. It only has two rust spots in one quarter panel and one rear passenger door. I have owned it for past ~6 years. It was a daily driver at one point, and then it was coolest Home Depot truck. I have all the records of everything replaced:
5/17/20225,555Oil change w/ filter, 7 quarts of synthetic 5W30
4/22/20225,555rear cross member install, frame paint, welded all the rust on the frame, new cat converter
10/3/17225,555Cross member cut for rear shocks.
9/28/17225,555Front brake pads, calipers, rear drum brake wheel cylinder, and a part of brake lines.
8/27/16225,555Flushed coolant, replanced two radiator hoses on the bottom
8/22/16225,000Rebuilt power steering pump, changed uppper radiator hose NAPA
8/13/16225,000Installed c-channels
7/31/16224,000Air filter
7/23/16224,000Changed all the belts
7/8/16222,000Oil change w/ filter, 7 quarts of synthetic 5W30
7/14/2015New transfer case and transmission fluid
Stabilizer bar link
7/5/2015Finished rebuilding transfer case
6/28/2015Transfer case rebuild
6/8/2015217,000Started disassabling transfer case
5/10/2015216,000Changed Charcoal canister
4/18/2015215,400Valve adjustment, valve cover gasket
4/17/2015215,000Oil change w/ filter, 7 quarts of synthetic 5W30
4/9/2015215,000Plugged up the plunger in carb
4/2/2015215,000Replaced fuel filter
