130amp, portable, made in the USA. Anybody heard of them? Will weld up to 1/4 inch steel with wire fed flux core. Seems handy if it is worth a s***.
You'd better use some gas if you're welding 1/4" Have a cheap 220 HF that works like a champ with a bottle of argon and was about $175 out the door, by far the best mig for the buck unless you're making your living welding.
You can weld 1/4" just fine with flux, just slow and not a very clean weld. Run a pass, chip off all the ****, run another pass...etc...
I carry a 20 bottle if I need portability, for me gas makes all the diff in a single pass that looks as good as it is strong and so much easier to puddle and stitch it along, but maybe thats just me. #20 bottle will get you a couple hours of straight welding and for my welder's duty cycle thats about a days worth!
Wirebrushing the slag off and making several passes isn't in my "love to do's" when it comes to welding but that would pass the time between duty cycles if you were bored!
). I'm not a huge flux fan.
