Hi everyone,
Not sure if this has been covered yet, but I'll ask just in case.
I was reading this forum recently:
Toyota 4WD Surf Owners :: View topic - Fuel economy mod for $2
It is in regard to putting in a tap before the MAP sensor to prevent the LJ78 from overfuelling, as the sensors seem to have a tendency to fail after a while. I noticed that my green turbo light turns on at around 2 psi, which apparently is lower than the original sensor was intended to do. Therefore, I end up overfuelling, according to the above forum, for most of my around town driving.
I put in one of the taps that they are talking about, and it seems to work pretty good. However, it ends up pretty gutless when driving on the highway. That being said, with the sensor on, even on the highway, the green light is often on when I probably don't need it (~80kmph when cruising on an even grade).
They seem to have come up with some pretty clever modifications on the above forum, but they're a bit too complex for me.
So, I was wondering if one of these MAP sensor enhancers meant for the HHO systems would do the trick:
The Water4Gas Report: How to Install the MAP Sensor Enhancer
YouTube - How To Install Adjust a Map Enhancer For Hydrogen Generator
What does everyone think? I think by reducing the increase in voltage from the MAP sensor, this might prevent the overfuelling that the LJ78 is apparently infamous for.
Any thoughts?
Cheers
Any thoughts?
Cheers
