Manual transmission to H2FAV t-case adapter?
Minneapolis, MN
Website
www.me.umn.edu
I am debating some engine swap options in a '94 FZJ80 and would like to swap in a manual transmission and adapt it to the H2FAV stock transfer case. I know there are many manual transmission options (H41, H42, H55f, SM420, SM465, NV4500, etc) for the 3spd, 4spd, and split t-cases of earlier Crusiers. I have seen AA's auto transmission adapters, but nothing for manuals. What adapters are out there for manuals transmissions to the full-time AWD t-case?
Thanks,
Jim Van de Ven
Well if you use a Toyota H150 or H151 both are bolt on to the block ( if you soruce with the bellhousing ) and both will fit on your t-case ..
Edit: actually you can make a factory fit with an H55F just need to source a specific bellhousing that come in the 7* series with 1HZ engine and H55F tranny but hten you will need another t-case .. ( the BF1A part time )
