Yes, under the Compressor On-Vehicle Inspection - Magnetic Clutch section, it has a visual inspection for grease at the clutch bearing, and it says inspect Magnetic Clutch Bearing for noise... start engine, check for abnormal noise from near the compressor when A/C switch is off. If abnormal noise is emitted, replace magnetic clutch
A little odd to me.. if I go out and start it up right now.. no noise. Turn the AC on then off... noise.
In the 3-D blowup sketch, it list three things as part of the magnetic clutch... pressure plate, rotor, and stator. It doesn't specifically list bearing. Do you know if the bearing is inside either the rotor or pressure plate?
I'll inspect closer for grease. I'm also going to double check the belt tension to be for sure.
Thanks,
Rookie2
