The V8 seems to make the most sense at this point.
82Cruiser, any updates or decisions on engine yet? Sorry, but I'm following your builds (especially your seating and hoops) and I'm fearful of the V8 for you...
local yard has full tundra motors for less than $1800 with low mileage with all accessories and electronics.
They get them in often, had 5 when I was there last week.
Just sayin.
I did not need to see that post... the lv is on the road leave the engine alone.....
how hard would that be to mount up to a H55 or a manual transmission in general?
Just sayin.
On a side note, from what Wally was saying the 4.7 will bolt up to the auto whcih is in the FZJ80. If you want to go auto too that would be a great swap because it would also give you the offset t-case.
...and if it bolts to the 80 series auto than it's not that far of a leap to say the 80 series 5-sp from Oz will bolt up too. I'm sure there is a manual trans flywheel for the V8 in Toyota's inventory somewhere you can use to get it all together (or some machinist dude might be able to make you a custom part if needed). Slee has swapped a couple Toyota V8's into earlier trucks and might be able to provide the tech support to make it happen.
Go for it Randy! Just make sure you buy the factory service manuals for the donor vehicle too so you can sort through the EFI wiring harness to make it go. Getting the motor bolted in is the easy part; making the EFI system talk to yer old skool vehicle is the real challenge.
Nick
