- Year
- 2011
- Vehicle Model
- 200 Series
- Mileage
- 237500
- Color
- Silver
2010 237,750 Miles.
I bought it from the original owner in Houston, TX with 100k miles. Was in AZ until 2019. MA since.
The Good:
Never had a mechanical problem. I have done all maintenance myself using Toyota parts and Amsoil fluids. I have a spreadsheet that tracks everything I have done over the years.
WORK DONE: -Radiator/WaterPump/Alternator at 150k. There was a design flaw where the radiator would crack on top. While I had it out I replaced other parts (hoses, water pump, alternator) as preventative maintenance.
-Added an internal door lock and handle to rear gate so you get out from the inside. Surprisingly it does not come with this from the factory
-Added additional cargo light to rear gate
-RedArc trailer brake controller.
-Caprivi seat covers. Ordered custom from South Africa. Very nice and I bet the seats still look new underneath.
-Slee dual battery trays. Never installed a second battery.
-Weathertech Floor Mats
The Not-So-Good:
-Rust: It has been in Massachusetts for 7 years now. There is some rust. I have included a bunch of pictures of the undercarriage. It is all cosmetic. Nothing structural or on the body.
- The KDSS valve body has surface rust but the adjustment screws still spin freely. I check them often and keep them covered in FluidFilm. This is important in case you want to lift it.
-TPMS is not working. I never replaced the transmitters when the batteries died. When you get new tires you can renew these if you want it to work.
-Center Diff does not currently lock. I suspect corrosion in the electric actuator that just just needs cleaning, but cannot get into the module because the small screws are corroded. To repair this you will need to open the actuator, clean the contacts and reassemble.
-The steering wheel does not move in-out. The electric motor needs to be replaced. Up/down works fine. I have a spare motor for it but it is not an easy fix in situ. The TSM calls for replacing the entire column which I think is silly.
-Front parking sensor is not working. I have not looked into it. Could just be a loose connector. I have a new replacement sensor on hand.
-Scratches on the body. Basically pinstriping from brush. Its in the pictures. Some can be buffed out, others can not.
-Front seat headrests have built-in DVD players. They work but are old tech and my kids cracked the bezels pulling on them. I keep them covered with headrest covers.Extras:
-I have an Android head unit that can replace the radio/center console.
-Spare headlights.
-Spare interior drivers door interior handle. The current one is scratched from wedding rings but still works and sits kind of loose. I ordered the new one but realized the old one is still working fine.
-New set of front brake rotors and pads.
RECENT MAINTENANCE:
-OIL CHANGE (Amsoil Synthetic, Filter)
-PCV Valve replacement
-Transmission Flush (Amsoil fluid)
-Transfer Case Fluid-Front and Rear Diff Fluid (Amsoil)
-Brake Fluid Flush (Amsoil)
LINK WITH PICTURES AND INFO
(Link to google drive folder with more pictures and an excel sheet that shows all maintenance history)
I will take more pictures on request. Available to answer questions.
Asking $16,500
The Good:
The Not-So-Good:
-Spare headlights.
RECENT MAINTENANCE:
Asking $16,500
