Hey guys, so I have a 2002 LX470 and since about a month ago, I've been hearing wur-wur-wur-wur sounds as I drive the vehicle. At low-speeds, the noise is hyper-audible because of low-wind speeds and whatnot, but at high-speeds, it's hard to hear with the wind drowning out everything. Anyways, this noise is also palpable through my feet on the carpet while inside driving; the noise correlates with the wur-wur-wur sounds being made outside. The noise does seem to originate from the front passenger's side.
Today, I jacked the front of the vehicle up and found that there was excessive play (?) while rocking the front passenger's side wheel from the 3-6 position (side-to-side). Not sure if this is normal or not, because the entire assembly was rocking together. In stark contrast, there was a sharper play from the 12-6 position (up-and-down) -- this may be what is causing the issue? Would this be a bad wheel bearing?
Moving on to the front driver's side wheel, there was also some play from the 3-6 position, but not nearly as excessive as the passenger's side. There was absolutely no play while rocking the wheel from the 12-6 position.
Here is a video to demonstrate the severity of the issue in the front passenger's side:
http://youtu.be/1ENskTbOyDY?t=2s
Can you guys please help me diagnose this problem?
Now, I also tried wiggling the CV half-shaft while under there and there was very slight horizontal play in the shaft. Considering the amount of grease exposed around the inboard boots, I'm not sure where a rebooting would be sufficient. Please advise. The picture I've attached is of the front passenger's side, but the same predicament is mirrored on the front driver's side.
Lastly, the vehicle is slightly tilted to the right from the rear, as can be seen in the pictures above. The rear right is about 1.5"-2" higher than its rear left counterpart on level ground. Any fixes to this?
Oh by the way, the rust is because I live in Michigan, unfortunately enough.
Thanks!
Thanks!
