Hey guys;
As I wrote this weekend, I love my "new to me" 2005 LX470 that we got last week, with one exception - the Ride/Steering. (See thread here for pics and info https://forum.ih8mud.com/100-series-cruisers/636439-upgraded-fzj80-fzj100-couple-thoughts.html )
Vehicle was just purchased from Lexus of Orlando and had a thorough inspection at time of sale, so there is nothing *visibly* wrong with it. Let me explain, and I will compare it to my 1997 LX450 with stock, original suspension at 175k miles.
On smooth roads, the LX470 rides great. Tracks straight and true under acceleration and braking. (LX450 is same, just way slower, ha ha )
On a 2 lane country road with even just a moderate crown, it pulls to the right, and requires constant adjustment to keep it going in a straight line. (LX450 doesn't pull at all)
On bumpy roads, it wants to pull whatever direction the bumps are........ie, I have to constantly adjust right/left to compensate for the bumps. (LX450 doesn't pull at all, no steering adjustment needed). It reminds me of my sister's Mini Cooper S, which is OBNOXIOUS to drive as it requires constant steering adjustment.
On bumpy roads with left-right pattern of uneven sections, the rear of the truck wants to "porpoise" or "wallow" in the same pattern, at 50mph. (LX450 doesn't wallow at all)
These observations are ALL made with the LX470 in N height setting and Middle shock position. If I go to SPORT shock setting, ride just gets harsher. If I go all the way to COMFORT setting, the wallowing is worse.
LX470 has 108k on it. RF tire has 6/32, the rest have 7/32". Front PSI 28, Rear 32 (approx). I have 9 or 10 graduations variance between LO and HI settings on the suspension in the AHC reservoir, though from the middle position, it doesn't like to raise if you're sitting in Park (the N light is steady and the HI light flashes)........it works better if you drop to LO and then go back to HI (it works perfectly then). Service records show 4 wheel balance and alignment was just done 200 miles ago. Looks like 2 Tie Rod ends done at 92k. Ft Brakes, CV Boot, and Rack and Pinion Assy replaced at 84k.
Any thoughts on where I should start looking? I am 3 hrs from a Lexus dealership, though I have a good Indy shop local here and a Toyota dealer 1 hour away.
I am thinking ft alignment is probably off, causing it to "hunt" and on bumpy or uneven surfaces. What about the porposing/swaying on uneven? Could I have a bad rear shock?
I actually LIKE the AHC ride on smooth roads, I just want it to ride and steer more like my 80 does on rough/uneven stuff, which is most of what we see here in Michigan
Thanks for any and all input
Ben
Ben
