Anyone experienced the following with their LX?
After about 40 minutes of highway driving, the suspension becomes stiff, like the "Sport" or full-hard mode. When that happens, it stays in this stiff mode, regardless of user setting.
Shutting off engine and restarting will reset the system to user-set mode, e.g., "Normal" or "Comfort" or whatever user sets.
Happens repeatedly now, with my 99 LX.
Any info appreciated.
TIA - T.
TIA - T.
I removed AVS & AHC combo switch (easy to pray out bezel and pull it using small flat screwdriver, then disconnect wiring). When I took switch apart I found that AVS contacts on PCB and rotor in a good shape but little bit dirty and worn out. I used alcohol and pencil eraser (red) to clean them up to "brand new" condition, then add small amount of electrical grease. All process takes about
10~15 minutes. And bingo! Now suspension works as new.
