I had Lou make me up a set of lights a while ago, and finally got around to installing them. I won't go into the install process, as that's fairly well documented, but I will say that it took me about 2.5 hours from start/finish, including making an adapter cable to use between the OEM headlight connector to the 9005/9006 plug that the Morimoto setup comes with.
At first, I thought about taking pictures outside, but I wanted something more controlled. My parking garage is dim and consistent, so I just parked at one end of the garage, and pointed the car to the other end. I left the camera in manual mode and all settings weren't touch between photos. Anyway, onto the pictures!
The old setup: headlights are Philips X-treme Vision H1, while the high beams are Philips X-treme Vision 9005:
Now the new setup. The high beams carried over, not that you can tell with the MASSIVE INCREASE IN LIGHT OUTPUT.
I am very pleased with this setup. Thanks Lou!!!
