Hello All,
I recently purchased a 2003 LX470 and have been trying to figure out a few quirks. Overall the truck seems great, but I have a few codes that I pulled with Techstream and some behavior that I am not able to explain. First the codes:
Engine - B2799
ABS/VSC/TRAC - C0210, C1223, C1224
Body - B1222
Now the behaviors:
Windows - When I press and hold unlock on the remote, I expect for the windows to roll down. Instead, after about three seconds, I just get a beep. I tried to use the key in the driver side door (expecting the windows to go up and down) and nothing happens.
Mirrors - For some reason, the passenger side mirror does not move with the memory seats nor does it dip when I put the truck in reverse. The mirror does move with the adjustment control, so I know the motors work.
Wipers - The wipers do not always return to their normal parked position. The often stop about 10 degrees up from their normal parked position. Sometimes they will try to go well past their parked position and slam into the lower edge of the windshield. I'm not sure if this is something physical or electrical.
I don't have any indicator on the dash related to the ABS errors, so I'm not sure what's going on there.
Any insight into what to check would be greatly appreciated.
Thanks,
Bill
Engine - B2799
Body - B1222
Now the behaviors:
Thanks,
Bill
