Self diagnosing for My lx470 a/c shows error code 26 and 41.the compressor is engaged with low discharge pressure and high suction pressure.any idea what could be wrong as I couldn't find in the web any thing mentioned code 26 or 41
Thank you a lot ,it is great to know about these two codes26 is the rear inlet air temp sensor. Could also be the rear A/C amplifier or harness.
47 is the rear air mix damper control servomotor. Could also be the rear A/C amplifier or harness.
Since you have two codes relating to the rear a/c, it could be the harness, amplifier (ECU) or just a loose or corroded plug.
