LX470 1998 bought 2weeks back without much of repair history and 85%Pass good engine sound and many feature working except some luxury off road feature high/low and 4wheel (may be motor burnt), well just a week ago it starts and stop some 4-5m run with indication on dashboard " AT Temp" and "Orange air flow"alarm signs. Then again able to start with no warning sign, in the steady position stops with above signs. ECR already appeared 4-5days before this incident with no trouble in drive. Before I could plan to pay a trip to mechanic this event happened. The car was then towed to garage and then he first checked computer, no issue, then cleaned air filter but no improvement, then removed massairflow sensor(differential pressure) no improvement,then changed fuel filter no improvement, then changed intank fuel pump no improvement, then cleaned injectors no improvement, now mechanic advised to change the fusebox. It looks he following an elimination technique and had no clear idea of the root cause. I just need helpful advice with possible reason if anyone undergone such failure/symptoms, also need fusebox photo ( I doubt mine not same as lx470, may be replaced one).is it possible to burn fusebox while checking / removing so many things here n there ? car still starts even with bad fusebox (as he says) but stopping on same alarms. To me as lay man it looks some wiring short or some relay malfunction after certain seconds of startup. Its either electrical related or mechanical fuel flow/spark/filter/injectors..... please advise.
