I have had these listed for a while, with very little interest:
https://forum.ih8mud.com/merchandise-storefront/434037-80-series-rear-lower-shock-mount-guard.html
but recently have sold a few and actually had to weld a set together after work yesterday. I don't know how many more I will make so I thought I would post the build details here in case anyone wants to build some. It's not rocket science and could probably be done more efficiently.
start with a piece of two inch sch40 pipe, cut to length and cut a slice across the seam that goes to about a 2" tangent to the pipe:
make two lengthwise cuts going to the slice in the top of the guard:
for the center I prefer to use a drop from a holesaw, because it has the pilot hole perfectly in the center. you can see one sitting in the foremost guard in the above picture. I only had one drop and I lent my hole saw to a friend so I had to cut out a center for the second guard.
space the center up so the bottom lines up with the top of the front lip:
tack it in place and center it:
weld all the way around the outside:
with good penetration the weld should go through to the other side, I ran a quick bead around the inside to make it look a little cleaner:
repeat for the other side and drill out the center holes to 1/2", clean up with flap wheel and you are done:
