- Joined
- Feb 24, 2010
- Threads
- 2,226
- Messages
- 2,226
Low Range’s Suzuki Differential Master Rebuild Install Kit With Solid Pinion Spacer has everything you need to make your gear setup a breeze. We weren’t satisfied with aftermarket bearing kits for the Samurai in general, so we made our own! This is the highest-quality kit available for the price.
Kit includes:
Solid Pinion Spacer
Solid pinion spacers take the place of conventional crush sleeves in setting bearing preload. They are slightly shorter than a crushed crush sleeve and come with several shims which are stacked to different heights to increase or decrease preload.
For many years, Toyota used similar solid spacers in their differentials. Their proven reliability has trickled out to other axles in the aftermarket and is now available for your Suzuki.
Why choose a pinion spacer over a crush sleeve?
In Short: Solid spacers reduce the risk of overtightening your pinion nut while ensuring a reliably stable pinion load.
PLEASE NOTE:
The post Low Range Off-road – Suzuki Differential Master Rebuild Install Kit With Solid Pinion Spacer appeared first on RockCrawler.com.
Continue reading...
Kit includes:
- High-quality bearings from Japanese companies like Koyo, NSK, and Nachi
- New high-quality solid pinion spacer
- New spacer shims
- New pinion staking nut
- New OEM-style pinion oil seal w/dust flange
- Gear marking compound with brush
- High-quality pinion shims
- Red thread locker
- Tube of RTV silicone gasket maker
Solid Pinion Spacer
- It takes between three and four hundred ft. lbs. of torque to crush a crush sleeve. For some with limited tooling, this can be impossible to achieve. Because solid spacer preload is set by adding shims, installation does not require such high torque.
- Crush sleeves are known to continue to collapse over time. This means that the preload setting on the pinion shaft can change and need adjusting. In addition, if you run your pinion flange into a rock you will likely further crush your sleeve. In contrast, solid spacers never shift in length and will not loosen over time.
- Crush sleeves cannot be reused. If you have to rebuild again in the future or if your installation does not go well the first time and you have to tear it down again, you can reuse your solid spacer again and again.
- With a solid spacer, you can change a leaking pinion seal without needing to reset the crush sleeve.
PLEASE NOTE:
- Proper set-up is essential for differentials. We always recommend professional installation.
- There is no one set of shim thickness that we can recommend. Each set-up will be unique.
Continue reading...
