Parting Out Low Mileage 2005 HDJ100 rolling frame (Part out or whole)
lelandEOD
Dayton, Nevada
I have a rolling frame I need to dispose of:
2005 HDJ100 rolling frame with 65000 miles on the odometer.
  • Complete right hand drive frame
  • Rear axle assembly with brakes
  • Rear upper and lower control arms
  • Rear panhard bar
  • Rear coil Springs and sway bar
  • Front and rear driveshafts
  • Factory 17 inch alloy wheels with run flats installed
  • HDJ100 diesel fuel tank, skid plate, and filler neck assembly
  • Front and rear air shocks
  • Complete front differential and half shafts
  • Front swaybar
  • Front upper and lower control arms
  • Front torsion bars
  • Front hub assemblies with disc brakes
  • Complete RHD steering rack
  • HDJ100 A750F transmission crossmember
  • HDJ100 chassis wiring harness
  • Complete air suspension system
  • Steering wheel, airbag, and column
  • Fan shroud
  • AC condenser and AT cooler
  • Front impact bar
  • Brake booster assembly
  • Air suspension reservoir/pump thingie
  • HDJ100 gauge cluster
  • HDJ100 A750 shift lock assembly
  • ABS TRC/VSC computer
  • Airbag control module
are the lower control arms sold? if not how much for the pair?
