i'm loosing the prime in my 1kz-te prado to the point that i need to pump the priming lever on the fuel filter to help it start. i disconnected the filter and vacuum tested it and it's ok.
i've also run a gravity feed of diesel straight into the injector pump left it over night and it starts perfectly. however, when standing i've noticed that fuel slowly drips out of the return hose (the banjo fitting on top of the injector pump) to the point that if left long enough the gravity feed empties itself into a bottle placed by the outlet on the pump (once hose removed).
am i right in thinking this isn't right and would be the reason i'm loosing the prime??
also, without having the cash to have the injector pump removed and serviced, what can i do about it??
many thanks.
many thanks.
