Wanted Looking for the fat version of the FJ60 transfer case shift lever
That may very well be or I could have one machined and thread or weld to my lever below the cover.
I have everything to make it function now. I was provided with the gearboxes.
As mentioned, the 70 series shift lever is fat. 36302-60180, available overseas.
Ordered the lever today State side.
$90.00
36302-60100 Front Transfer Drive Shaft Lever for 11/84-8/87 60
Series
So you purchased a used one? That part number is for 8/87-2/92. 36321-60130 is the 11/84-7/87 with 36302-60100 as a sub. Both work just the later is fat.
Score if you get the fat one. I have the late eighties thru most the nineties then the late nineties on. The early one should be close as it was fitted to a H55F and split transfer case.
I had seen the vacuum shift levers with the wrong linkage for more money that would have to be cut and welded to the shifter that was provided with my H55F and transfer case. Was not able to find a new one.
Thought those vacuum style shifter were plentiful. Have three extras laying around. Never paid close to.that much and couple came with the boot. Would be curious how long the fat section is on the one your getting. The fat section is longer on the 60 series vacuum shifter than the two different 70 series shifters I have. Since I have the 40 H55F top cover looking to move the shifter forward to match the transmission shift cane. First picture is the stock 40 series shifter. Other two are 70 series.
It just shipped today from NH with the parking brake bracket and rear axle brake lines. Not sure when it will show up, but some time this week.
Yes it did and have it put away on the shelf for when I can install the transmission and TC.
